ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I would run 1.325s(woodys length) if I ran another 1 inch sneaker....I used to run 1.175s woodys for yrs on all my 1" tracks and they did OK, but nowadays I think if I did have another 1" id go 1.325 for sure.Dan, how far above the lugs do you like the studs? I've decided to run the 1 inch next year with studs, and I have 1.375's. These are about 1/2 past the lugs.
Too long?
My 1.450s when new showed 9/16 over the lug, i did not think it would be that much but it was. Sure works pretty good. But also need to be thoughtful with your right thumb.
Im thinking I will go with less Qty next time around....but do worry about the 1.450 length if I only go with 2/per bar. Now im avg of 3/bar with a 2/4/2 pattern. For now things are staying as is on my sled.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Wrong the outside studs allow you to turn with out letting off the throttle
Your miss informed studding the center is only good for going in a staight line no good for trail riding
You are 100% incorrect.....
Either you typed it wrong, or you have it completely backwords....not sure which.
-Outer band studding will ALWAYS PUSH MORE and need MORE carbide on skis.
-UP the middle studding will ALWAYS TURN BETTER and need LESS Carbide on skis.
Dan
Fast
- Sep 25, 2018
Dan
Dan i thought you would of known this but hey i guess thats why you cant believe everything you read on hereYou are 100% incorrect.....
Dan
Fast
- Sep 25, 2018
Yes more carbide but center only will pull the sled straightYou are 100% incorrect.....
Dan
Fast
- Sep 25, 2018
Really??You are 100% incorrect.....
Dan
lilrez
If you plan on studding , ensure you run a track.
Fast
- Sep 25, 2018
Fast
- Sep 25, 2018
I guess we found out why they think the 129 transfers better crack it and the skis are off the ground let off too corner and back on the throttle againReally??
