02xtreme
Bought an Ulmer kit and it came with 4 spindle bushings. I loosened the steering knuckle assuming it would allow the ski column to slide out but the ski column is not budging. Even hit it with the hammer and nothing. Yamaha manual calls it a ski column, I call it a spindle.
So my question is how do I remove the ski column to install the bushings
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I have a link blow that should help. If I'm thinking what your talking about.
chiefsledhead
I believe you have to remove the bolt, not just loosen it. There is a groove at the top of the spindle and if the bolt remains in, it won't let the spindle drop down.
Honk
Yep! remove the allen head bolt with nut , will drop into your lap.Bushings top and bottom.It will tighten it up alot. Make sure to do the steering colum bushings, my worst one was behind the oil tank.
02xtreme
Ah, forgot have to actually take the bolt out. Should have remembered this from last time. Thanks
