Could be low voltage. Make sure the battery has a good charge
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Same boat here with TD flasher. No BT connection. Tried wifes phone no connection either. Have PM into @GAP Innovation. Seems like I have to relearn this thing every year. Flashing to single MS16 SM and throwing that thing in a drawer. As a Mac user I own a Compute Stick SOLELY for this purpose.
Hmm. Was this on a PC laptop?
DeBo
- Mar 30, 2019
- NH
- Sidewinder
I have the new battery on a trickle charger tonight. I'll try in the am.
If I buy the cluster then it won't matter if it works unless I wont to change things. Spend more money or have it work like it's supposed too.
Glad I'm not the only one
I seem to remember issues with non PC laptops in the past, but I don't know if this has been rectified
DeBo
- Mar 30, 2019
- NH
- Sidewinder
I have a pc laptop
Ok DeBo. Hopefully a full charge will get you squared away.
DeBo
- Mar 30, 2019
- NH
- Sidewinder
Thanks for the help. I will certainly update them.
DeBo
- Mar 30, 2019
- NH
- Sidewinder
Battery full charged and no go on the Bluetooth connection. Must be burnt out. Got a lemon
actionjack
- Apr 9, 2005
This did mot fix mine but check your Bluetooth Privacy settings to make sure Gap has BT accessBattery full charged and no go on the Bluetooth connection. Must be burnt out. Got a lemon
DeBo
- Mar 30, 2019
- NH
- Sidewinder
Its under my Bluetooth options.
actionjack
- Apr 9, 2005
If this was a question for me a Compute Stick is a full Windows PC in very small form factor (smaller than a TV remote) Mine is Intel Core m5. Plugs into TVs HDMI for anywhere PC use. Only used really for updating my Flasher.Hmm. Was this on a PC laptop?
Thinking even if the files were corrupt you should still be able to connect the flasher to the phone. I ran in to this couple weeks ago where the crappy wifi wouldn't push the tunes to the communicator but when plugged into the sled I could still get my phone connected to the communicator via bluetooth. Have you tried to remove the com. From the list of paired devices and tried to search it again?
