Carpet Guy
So I'm kinda disappointed that I got beat today buy a 280 set up from another tune and mine is the 300 bundle tune was running 19 psi for boost and probably 8700 rpm,both the same sleds and I had more stuff done to mine so I need to figure out the clutching
RAMSOMAIR
It will happen. You’ll have days like that. Many many variables to overcome.
The redhead is never dead
Im still in awe that a guy can use a 300hp snowmachine these days and not blow it up. Thats incredible!It will happen. You’ll have days like that. Many many variables to overcome.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
More specifics.
Sanctioned or just racing your buddy type racing,
Surface, length.
Tough job specking this style/class sled isn’t it?
I mean, how sure can you be with your claim?
Surface, length.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Either way, sled set up means a lot per conditions and length.
I'm still running stock, but dont you want to be running 8900 rpms? Same sled is fine but if one is picked and or has more picks that can hurt top end. A tight track will have a tough run against a loose track. Plus some motors are just stronger too. What tune was he running?
number1kyster
So what? Setup is everything. He may be clutched better than you. Did he have the same gearing, studs, suspension setup?
There are so many variables. A good setup can overcome a bad setup with more horsepower. It happens every day.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
To many variables just playing on trails or lake imo.
I race a tuned 900t. Supposedly 215HP and was about a sled each time on him at the end. I think he should have one but oh well. Happens is right
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
yup. These things are not just plug and play. The more you test and adjust, the better your set up becomes.sled set up means a lot
Carpet Guy
More specifics.
Surface, length.
We r both studded hes got 48 more tho my track is tighter and we do have different clutchingSo what? Setup is everything. He may be clutched better than you. Did he have the same gearing, studs, suspension setup?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
clutching and track tension alone will contribute to one running faster. That plus traction.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Muffler difference on each, Studs, clutch setup, suspension setup, RPM, belt being used. You got to know how to tune it and what you need to beat the other guy. Like has been said, its not plug and play. I can take a 600 and beat a sidewinder on the ice if your not setup to play.
The HP rating means nothing.
Carbide
- Apr 20, 2017
- Elk River, Minnesota
- '15 Apex X-TX -SOLD
'21 Sidewinder L-TX SE
- Minnesota
Maybe he mixed in a salad. Lol.
Carpet Guy
Well a little bit of both mostly trail but we raced on a lake and good conditionsTo many variables just playing on trails or lake imo.
