Dicker from JP
- Nov 12, 2014
- Jacksons Point,Ont
- 2015 srViper l-tx se
Just got my first real good run in with the 190hp kit. I got Daves clutch kit,gears and chain mod also. I ran 117mph on a small lake and still wasn't WOT. I give Daves kit the thumbs up.
suburban
- Apr 19, 2003
- ontario
- 2021 SRX
I'm with you on that! Go big its the best deal. Dave kit has the best Ball bearing Garrett turbos, MPI is just Mitsubishi journal bearing turbo bout half the cost.
IMG_2279[1]
270-400 hurricane Garrett 2871R ball bearing turbo, no Mitsubishi junk here.
yep, Dave's kits are simple, uncomplicated and flat out work.
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
And I'll add to that, No upgrading needed with Dave's kit. It comes with all the good stuff !
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
$3200 for a turbo and clutch kit, sign me up!!, anyone need a bv clutch kit and ulmers intake, lol
tator
Just got my first real good run in with the 190hp kit. I got Daves clutch kit,gears and chain mod also. I ran 117mph on a small lake and still wasn't WOT. I give Daves kit the thumbs up.![]()
what gears are you running? i wend with 22-41 which is still to low.
Dicker from JP
- Nov 12, 2014
24-41what gears are you running? i wend with 22-41 which is still to low.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What length chain is that?
Dicker from JP
- Nov 12, 2014
Pretty sure its one link shorter than stock.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I am running 21-41 ==1.95
That 24- 41==1.71, that is pretty tall. That 190 still pulls those gears pretty well?
Dicker from JP
- Nov 12, 2014
pull like a bat out of hell...So crazyI am running 21-41 ==1.95
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
think I'm going to reach DEEP in my pockets and take the plunge hurricane turbo sounds awesome!!!pull like a bat out of hell...So crazy![]()
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
Did not see this coming!
tator
i went 22-41 and its not tall enough! should have went 24-41.
Woodward
- Mar 27, 2013
- Belleville, Ont.
- 2016 viper xtx
I am also running 24/41 gears with 88 link chain, 8 tooth drivers (stock on xtx was 21/41 86 link chain) with hurricanes 240 kit and clutch machining and it pulls very hard! Iv seen 118mph but am sure it has more as I am still playing with clutching. Keep in mind this is an xtx with the 1.6 cobra track and 141 1.860 powerpoint plus studs.
