canuk77
Well i hit a nice rock today about 10-15mph and bent my sub-frame,skis were pretty far out of alighnment.I was wondering if the new one i order is an updated sub-frame or not from yamaha.
Here are a few pics of damage...it kinked right on the corner where the boot is rivoted...the left shock also hit upper a-arm and bent it...
Grimm
It should be.
teamfrosty
- Jan 12, 2011
The old frame is not available from Yamaha anymore. Now all frames they sell are those stronger ones.
raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
Welcome to the club I have the updated 2010 subframe and I managed to bend it aswell without hitting anything.
teamfrosty
- Jan 12, 2011
Here's what I did to my second updated frame. Helped a bit.
mach9
On my 3rd sub frame.
2010 version now.
2010 version now.
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
teamfrosty said:The old frame is not available from Yamaha anymore. Now all frames they sell are those stronger ones.
Yep, doesn't take much to bend the original. New is stronger...
NsNyTro
Just curious...How much are these sub Frames going for?
Grimm
They're about $800 in Canada and $450 in the States.
09nytro
I have a spare in my shop ( subframe that is ), Hay GRIMM do you use that horn much
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Grimm said:They're about $800 in Canada and $450 in the States.
Hmmmmmm and our dollar is worth more??
sleddingfarmer
They are $800 in canada? Holy that is ridiculous!
teamfrosty
- Jan 12, 2011
Warranty covered my frames. New frame is a lot stronger, but not strong enough. That's why I welded some reinforcement to it.
I also welded lover A-arms nuts to the frame. Original holes for A-arm bolts are little too big, so the bolt can move in its hole if it gets a hair lose. That causes A-arm to get more movement to bend the frame.
BTW, new subframe is 900 euros in Finland. That's about 1200 USD
NsNyTro
You would think Yamaha would have this issue fixed by now..i understand that some people may have hit things too hard but i've read about people bending them and not even knowing how it happened..I have a 09 subFrame in my 08 RTX(it was updated by a Yamaha dealer) As far as im concerned these Nytro's are a work in progress for Yamaha...i love the Sled but I think i'll be on a 2011 or 2012 Apex next season...How can Yamaha justify $800 Can and $450 US????Grimm said:They're about $800 in Canada and $450 in the States.
Grimm
09nytro said:I have a spare in my shop ( subframe that is ), Hay GRIMM do you use that horn much
A spare frame is always agood idea. I think Grizztracks sells reinforcements plates that you can weld in to strengthen the subframe.
I've only ridden a couple of days this season, gave a blast of my horn and turned some heads.
