Well I do not have any pictures but they install easily. They come with a small square tube steel bracket (post) that mounts to the rib on the ski just behind the ski mount and then the actual scratcher simply slides over that post and a spring clip keeps them in place. The post stays mounted on the ski and then the scratcher can either be removed or rotated 90 degrees for storage when not in use. I remove mine and keep them in my storage bag on the back when no using, but rotating works as well. As I have said, the only issue I have had with them is losing the little rubber covers that fit over the posts when the scratchers are removed. You can easily adjust the angle on the scratcher for more or less contact by simply removing a small pin and change the angle and re-install the pin. I played with mine at first, but quickly found the angle that gives all round performance for me and they have stayed there ever since.
