superb
- Apr 10, 2004
- Ottawa, Ontario
- 2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
My 2015 Ltx Dx idles from 1450 to 1550 and sounds like it has a high lift cam in it. Is this normal?
Glen1027
- Nov 10, 2014
- Moose Jaw Sask Canada
- 2014 Yamaha SR Viper XTX
My 2014 xtx idles at 1450 to 1550 after my ecm update. Before the up date it would idle at 850 to 1000 and it was to slow the sled would die out ever time I would come to a very quick stop. After the update it has not done it again I have tried.
1800 cold cold dropping to 1500 when warm
superb
- Apr 10, 2004
- Ottawa, Ontario
Thanks Guys.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
My "new leftover" 2015 RTX does the same thing, varying idle swinging 100 rpm. It had the ECU reflash update in Oct when I bought it. I'd like to know if this is typcial or something I should look into. I kind of expect that an EFI controlled 4 stroke should idle smooth as silk, especially with electronic idle control?My 2015 Ltx Dx idles from 1450 to 1550 and sounds like it has a high lift cam in it. Is this normal?
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
I have less than 500 miles on it and it's audibly noticeable when off the machine too, can hear it's hunting...My "new leftover" 2015 RTX does the same thing, varying idle swinging 100 rpm. It had the ECU reflash update in Oct when I bought it. I'd like to know if this is typcial or something I should look into. I kind of expect that an EFI controlled 4 stroke should idle smooth as silk, especially with electronic idle control?
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Normal!
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
My 14 RT-X, 1800 rpm cold and 1520-1500 warm. Has MPI with almost 7k miles.
Normal lope we have been talking about for 5 years. It’s the tune but nothing other than a reflash or tuning with PCV will fix it. Just tell people it’s the Cam timing.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Cool, I'm Ok with it then. My big 310 HP turbo Apex hunts a little too but not this much.
Hurulau
- Oct 29, 2015
- Finland
- Other
- -15 Viper XTX LE (mcx270)
My -15 mcx270 viper start to idle roughly from 1000-2000rpm. Any ideas what cause that?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Mines smooth 90% of the time, purrs like a kitten. 10% of the time, usually after running hard and coming to a stop, it does the "cammed up" 1450-1550 thing.
walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
Was worried when I first did the turbo kit, did the same thing with the high cam sound but yeah normal, and sounds cool
