Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
just wondering if anybody has had a issue like me. Just rolled over 2000 miles and two times when I was turning right at low speed like one or two mile an hour my sled stalled out. Two other times when I coasted to a stop it stalled out it starts right back up and runs fine and when I brake two a stop it's fine and when I coast to a stop after the two stalls it didn't do it never had it happen before just annoying any ideas?
No codes? First year I got mine it did that accompanied by a P code just once. 15 flash eliminated that.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I had the exact same issue it was tps
Worth a check on gauge
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
No no codes and it is a 15 I would imagine it has that flash-what did you have to do to fix the tps
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Do you know how to go into the troubleshooting menu on your gauge?No no codes and it is a 15 I would imagine it has that flash-what did you have to do to fix the tps
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
No but I have a service manual is it in there
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Read the link I just post (last 3 posts)No but I have a service manual is it in there
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Turn your key to the on position (not start) and hold bottom left and right button for 5 sec to bring up troubleshoot menu scroll down to tps
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
Yes just did thank you I will look into that tomorrow thanks good thinking
Clamb
- Oct 2, 2016
- Peoria IL
- Peoria il
I will post after I check it out
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Mine was out when I cranked bars to the right causing my sled to stall
So check with bar cranked right left and center
Make sure to press throttle and release.
Mine showed 0% when bars were cranked right until I pushed and released thottle and it showed 4%
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Hope it's the issue it's a simple fix
