RX-Kid
Anyone have some suggestions about how to get a bearing off the axle. Banging with a hammer didn't work. Think I can heat the bearing a little bit so it will expand, then hammer off? Or should a purchase a puller?
kinger
Little heat and she'll pop off.
Indy
You just need a 3 jaw gear puller. You can borrow one from Auto Zone. They are pretty cheap to purchase. Every sled owners garage should have one.
Convert
a little heat works wonders
LazyBastard
If its really really REALLY bad and the heat doesn't work, smash off the outer race, balls, and cage, and use a 1/4" grinder or dremel to cut the inner race.
Indy
Just go get a 3 jaw puller. Don't need heat or a hammer. Sandpaper the mount and install new wheel.
- 6K
