Italiangreatone
- Oct 13, 2015
- Massachusetts
- 2005 yamaha rs vector
Any help would be greatly appreciated. I have a 2005 rs vector and I need to replace the inside forward most idler wheels. I already bought the wheels took off the skid and now trying to figure out how to replace those wheels. Any help would be greatly appreciated. Thank you
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Not that difficult. Just unbolt the front shock and rear pivot, unbolt the shaft from the skid rails and pull out. Remove the set screws from the retainers at each end and slide them off and the wheels. Possible problems are the set screws that are seized or the retainers and/or wheels seized to the shaft.
Italiangreatone
- Oct 13, 2015
- Massachusetts
Thank you very much. Well explained. Just one other question. When removing the bolt from the shaft to the skid the end of the torsion spring is in the way when the bolt is 3/4 way out. Any recommendations on how to do this. Thank s.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- Greely, ON Canada
You'll have to remove the outer idler and bracket that holds the spring.
Italiangreatone
- Oct 13, 2015
- Massachusetts
Great thank you.
Sleddog1
- Sep 19, 2015
- Niagara Falls
- 2000 SXR 700
2008 Vector GT 40th Anniversary
2014 Viper LTX
Woh!! Those idlers are pooched! Just goes to show that people ignore their suspensions until something bad happens. Good for you for pulling it from the sled.
Italiangreatone
- Oct 13, 2015
- Massachusetts
Yea I just bought the sled I seen these when I bought it. I can't believe how bad these are never seen anything like it lol.
