ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
I seem to have bad luck working on things lately, and do not want to break anything. I'm changing my plugs, and have the tank pulled back for easy access. I assume you just pull on the coils to get them off. I have tried that but maybe with not enough force. Is there a trick or something to removing them.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I did this yesterday. Unplug the connector. Rotate back and forth to loosen things up a bit, then twist and pull at the same time. They are tight. Be careful not to break or put leverage on the connector.I seem to have bad luck working on things lately, and do not want to break anything. I'm changing my plugs, and have the tank pulled back for easy access. I assume you just pull on the coils to get them off. I have tried that but maybe with not enough force. Is there a trick or something to removing them.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Thank You. Just got done using the method described above.I did this yesterday. Unplug the connector. Rotate back and forth to loosen things up a bit, then twist and pull at the same time. They are tight. Be careful not to break or put leverage on the connector.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Be SURE you get them fully down when installing.
Turboflash
- Mar 18, 2019
- Southern MN
Also helps when reinstalling to lubricate the outer area where the ribs are with something like silicone dielectric grease. Makes it easier to get off next time.
ryama
- Mar 3, 2009
- Kitchener Ontario
- Sidewinder R-TX
- Kitchener
Good point. I rechecked after reading this and I noticed all three are about a eighth of a inch from being fully seated.Be SURE you get them fully down when installing.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Little dab will do you!Also helps when reinstalling to lubricate the outer area where the ribs are with something like silicone dielectric grease. Makes it easier to get off next time.
Turboflash
- Mar 18, 2019
- Southern MN
Yup, they go down hard the last little bit as they engage the threaded tip on the spark plug. Just look to make sure that biggest round diameter is tight down to the valve cover boss. If there's a gap, the coil is not down all the way. Helps that you have the gas tank slid back.Good point. I rechecked after reading this and I noticed all three are about a eighth of a inch from being fully seated.
