Philip Morneault
- Mar 21, 2018
- Maine
- 2006 Rage
So I got the sled the end of last season, put about 400 miles on it and only thing done then was to try the suspension setup by I think theCatman (not sure now). Sled does not have clicker shocks so only did what I could and for the most part it was just checking and verifying they were set that way (I changed I think front preload only). Didn't improve the issue which was darting and rolling.... But I love the lineal power and quietness of the engine (mileage was 15/16mg).
Over the summer I did the following maintenance and mods:
Regular engine maintenance ie oil, plugs... but did not adjust the valves. (note has 9500 miles on it.)
Replace exhaust donuts
Put new easy start clutch spring
New belt
Cleaned clutches
Skid got new slides, all new wheels and did the 4th wheel kit.
Changed skis to an AC M800 with new 6in carbides (wider to help it float better, Ive used them before)
Adjusted ski alignment to 1/8in toe out and corrected handlebars to be centered when skiis straight. (note there is play between handlebars and skiis and did not get to fixing that.)
Put a higher WRP seat on and raised handlebars 5 inches (and all cables got lengthened as needed)
I think that is it, impressions after mods:
Still love the engine both power and noise reduction and mpg has increased to 17- 17.5.
Ergonomics of seat and handlebars is perfect for me, very comfortable, and suspension feel for comfort is there too. Not quite as smooth as my AC F5 LXR but good enough.
Handling is the issue, still has bad darting and rolly feel to outside of direction it darts.
Suggestions?? I see people say they set the toe out to 3/8 to 1/2in, I am gonna try going to 1/4 first and then more. Also will a stiffer sway bar help? I see there are 12mm and 13mm but I see some people complain the ride is too harsh with the 13mm. Looks like 12mm comes stock on newer sleds but what years/models? I could try to get a used one.
Thanks!
~ Phil
New belt
Cleaned clutches
Thanks!
~ Phil
