stevesweeney22
- Jan 20, 2026
- Michigan
- 2013 Yamaha Venture GT
I bought a 2013 RS venture GT with studs and for some reason it did not have tunnel protectors added. I've made several calls around and it appears the Yamaha dealer network nationwide is all out of stock with no aftermarket options available.
If anyone knows of a pair or has an extra lying around please let me know - SMA-8ET21-50-10
TIA!
TIA!
RobX-1
- Coldwater, OH
It appears they did not come with them from the factory as there are none listed in the microfiche. I suspect that part number was for a Yamaha kit they once offered.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Check with barn of parts. He most likely will have a set.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Man, I could have made some $$$ when I ripped mine off when I replaced the track with a non-studded one. They were loose and made a racket. They went to the recycler.
stevesweeney22
- Jan 20, 2026
- Michigan
Unfortunately he confirmed he did not haveCheck with barn of parts. He most likely will have a set.
maybe you could mod a set of apex xtx ones to go in there?
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I asked around a few years ago and there were none. Now I don’t run studs for that reason….
Fast Lane
- Feb 6, 2020
- Winnipeg
- Winnipeg
Rear Tunnel Exchanger Protectors | SchmidtBrosMotorsports.com
Protect your rear tunnel heat exchanger from damage due to a studded tracks. These stack-on protectors will give your studs the necessary clearance when you bottom out at the rear axle. Example of heat exchanger damage from a studded track
- 25K
- 18K
