Inner tie rod access
TD Max
Central WI/Hazelhurst WI
Is there a way short of pulling out the air box to get access to the inner tie rods and bellcrank? Maybe through the boots? I'd like to get in and add a couple drips of Eezox lube to the heim balls etc. Best if I can get close and use the needle dripper.
Hood off and thru the intake is about your best bet short of pulling the airbox
Right side tie rod boot (as per Cat directions for the M8 loose bellcrank bolt issue fix)
I am glad it's for lubrication NOT POLISHING. I was thinking you were on a real out of control binge of the metal polishing lol.
