mmmkokanee
installed the new heat exchanger and polished half of the tunnel so far...install was pretty straight forward. You do have to cut both sides of the tunnel and drill holes for the rivets. I would have liked it to be at the back of the tunnel extension, but i just mounted it where the instructions said to. It looks a lot more impressive than that POS rear tube that was there!!
mmmkokanee
finished pics:
spray25
Looks good. Why don't you come install one for me.
Mountaintech
Too bad they don't fit the custom tunnel extensions. I wish someone would make one that would.
KbxSrx
WE DO!
you email me a picture of what exactly you want and I will make it for you, I am going to be at EKHOLM for the next month or so.
klysons@telusplanet.net
mmmkokanee
if idaho wasn't such a long drive, maybe i could hook ya up...it wasn't very hard to install
spray25
Re: WE DO!
While you are doing it you micht as well make two.
KbxSrx said:you email me a picture of what exactly you want and I will make it for you, I am going to be at EKHOLM for the next month or so.
LazyBastard
RX FUN said:Too bad they don't fit the custom tunnel extensions. I wish someone would make one that would.
They fit fine, you just need to add a drop. I used 1/2" copper plumbing pipe, put a couple bends in it so that its the same width as the tunnel, and flatten the part past the bends then bolt to the side of the extension.
LB
The copper pipe will last for a little while until ice gets behind
it and you try and knock it off. Try using a piece of alluminum
flat bar works great. Canadian Tire 3/4" x 3' $7.00
TB
TB
LazyBastard
Ice won't get behind it - heat exchanger makes hot all the time.
Mountaintech
LB, Looks like something I saw on the Red Green show!!!!
LazyBastard
WTF U talking about? There's not a stich of duct tape anywhere. :ORC
Mountaintech
Didn't you see the copper pipe episode a few years ago?!
LazyBastard
I have to admit that I don't watch that show.
Copper pipe is good stuff. Light weight and strong. Tubes are stronger than flat.
slymax
Wrap the copper pipe with duct tape!!! LOL
