Nytromike0208
- Feb 26, 2021
- Quebec
- 08 yamaha nytro
Ya I have the service manual, and did step by step, I have even watched videos I'm obviously doing something wrong or something else is going on. At this point a service manual isn't going to help me with the walk through
Go through the steps again.
Are you sure you are using the right cylinder?
Compress the photos before trying to post them.I cant seem to post pics
Nytromike0208
- Feb 26, 2021
- Quebec
- 08 yamaha nytro
I have gone over the steps multiple times, I am using #3 cylinder the one closes to the magneto top dead center on compression, even used a balloon on a compression test hose, lined the cams up so the dots in the camshaft were straight up, also lining up with the camshaft covers. #3 valves are still hit on the cam lobes. (Valve clearance was checked before and was at the proper reading 0.21mm).
