installing used MPI 190 kit, WANTING TO ADD EABC?
..SNAKEBIT..
NE Iowa
I just bought a used kit to install on my MTX, but it doesnt have the EABC with it.
do I but this from MPI, or would I be better off with something different?
couple trips to the snowies and maybe ride around Iowa or Wisc.
EABC would be best bought from MPI, to me its the only safe way to go with changing elevations like you ask.
You using the same AFR & boost gauge on all, looking for the best bang for buck.
I use the Koso X2, the only issue is if you run HID lights it can mess with the AFR guage on start up. I had to put a on/off switch in it to fix the problem
