breakinbarrs
- Dec 31, 2007
- Not North Enough,Ashburnham MA
My daughters 03 RX1 had the instrument cluster quit today while riding. The backup beeper and tail light both run and brake light went out with it. I checked to see if the plug was secure in the back of cluster and it was. Has anyone run into this and what was the cure. Thanx.
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
I had mine go out today as well the fuse box is on your right side if your sitting on the sled it is a 10 amp Labled SIG on the box.
Im going to look at mine this week to see where my problem is. I think its a chaffed wire under the toolbox on the right where the wires go along the frame. Most RX models have had a problem there so there is a place to start for you.
Let us know how you made out.
Len Todd
Check all the fuses. If a fuse is out, you going to have to find the short. It is highly likely that there could be a chaffed wire in the nose of the sled or at the handle bars. And, ... it is the Signal fuse as previously stated.
breakinbarrs
- Dec 31, 2007
Thanx guys I am on it today.
breakinbarrs
- Dec 31, 2007
It was under the tool box! There is no other site like this one!
04rxw10
- Jan 28, 2008
im glad you found it im going to looks at mine when I get out of work today
yamahamaniac
- Jun 2, 2009
- Jackson's Arm, Newfoundland, Canada
I have a slight problem with the tail light on my '03 Rx-1 M. The light is on but whenever I press the brake it doesn't get brighter. Any suggestions??
yamahamaniac
- Jun 2, 2009
yamahamaniac
- Jun 2, 2009
yamahamaniac
- Jun 2, 2009
yamahamaniac
- Jun 2, 2009
Woah, sorry guys, I did not intend for it to post that many times.
you have checked the bulb?
04rxw10
- Jan 28, 2008
Check the bulb and pull the seat off and look for caffed or broken wire
