I guess that shaft is now available from Minnesota. I will be buying one. Two Bolts is better than the one long one. It stretches. If you just want a steel shaft the 13RR has one. But mine loosened and egged out rail even with that in there. But at least shaft didnt bend!this seems to have been an issue since 12'...whats the solution? I saw a steel shaft from sweden that is supposed to prevent this?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Where? Link?
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
After most every ride I spray the moving shafts, shock rods, springs with white lithium grease, relatively dry, and seems to preserve the smooth movement, and prevent corrosion.
I use WD. That’s a good idea to do. But it won’t prevent the type of damage being discussed in this thread.After most every ride I spray the moving shafts, shock rods, springs with white lithium grease, relatively dry, and seems to preserve the smooth movement, and prevent corrosion.
