Dinner
Just throwing this out there being as most Viper have the skid mounted not square to drivers/axle. Check to see if your Anti Stab wheels are hitting the sides of the track lugs, causing a vibration. Something else to check that's all. It took me a lot of fiddling and adjusting the track to get it "square" enough that all the idlers run somewhat where their suppose to be...I also took my Anti Stab idlers off because the track (the inside lugs) would always catch them and cause a vibration.
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
http://ty4stroke.com/media/fb_img_1450230491669.843/
This is happening when the skid is in the upper hole. you must have it in the lower hole as it will hit the track drive
Majicgoats
- Dec 16, 2016
- Northern Minnesota
- 2016 Arctic Cat XF 8000 High Country Limited
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Does your sled not have two sets of holes in the front? If you put it in the lower holes they are also a bit further back. They dont need to change the rails, they just need to put them in the right holes from the factory. They didnt on most.
Majicgoats
- Dec 16, 2016
Does your sled not have two sets of holes in the front? If you put it in the lower holes they are also a bit further back. They dont need to change the rails, they just need to put them in the right holes from the factory. They didnt on most.[/QUOTE
I have already moved my skid frame down to the lower hole on the front and the to the center hole on the rear per the bulletin. I disagree with the thinking that there are "right" and "wrong" holes to bolt the skid frame to. A snowmobile should have multiple skid frame mounting holes so that a rider can adjust their sled to fit their needs. Raising the front of the skid and lowering the back puts more pressure on the skis and doing the opposite would of course do the opposite. The fact that arctic cat is claiming that they were simply just mounted in the "wrong hole" from the assembly line is a way for them to excuse their way out of a more costly bulletin fix, such as providing all new shorter skid frame rails to allow rider choice in which holes to mount their skid frame.
Dinner
Was this directed towards myself or the OP? If me, STX's do not have this issue due to smaller drivers.
Motorboat
- Jan 19, 2015
- New York
- 2015 SR Viper RTX
My 15 RTX started the rubbing noise at 5,100 miles this past weekend. I will be lowering the skid tomorrow. Glad to see I am not alone as I was a little baffled looking it over yesterday.
Sledhead5522
- Dec 21, 2017
- NEPA
- 2014 Viper XTX
Hi all. Just signed up on TY!!
Has anyone lowered the skids on 14/15 XTX's, or is this only on 16's? Any preference?
I did drop mine down but had to mill a slight amount out of the rail adjuster to get a little bit more out of it. Moving the skid down and back takes up quite a bit of slack. This is on a 14 XTX. I can't imagine many other folks doing this, but have seen a few stories with extension kits.
Welcome and Merry Christmas!Hi all. Just signed up on TY!!
Jon Boron
- Oct 8, 2019
- Maine
- 2016 SR Viper XTX SE
Old post but thought I would add that I just bought a 2016 XTX SE this spring with 1500 miles on the clock that is still mounted in the incorrect upper holes. Only was rubbing on one rail tip though as the previous owner must have hit a stump (or something buried in the snow) with the right rail tip as its bent up 1/2" higher than the left. Guess the solution is the go ride and whack the other side on something instead of taking the trouble to move it down/back...j/k.....its in my basement now getting ready to swap out the rail so I can get the track alignment back. Thanks for pointing me in the right direction
Powderfreak
- Apr 4, 2020
- Norway
- Norway
- Sidewinder MTX 2019
Hello;-)
Found this tread to day, and i have the same issue. I read that to solve the issue, you have to losser the front skid mount to the lower hole.
But my question is, how does the sled react to these changed? Will the change make the sled bee lighter on the skiis?
Vmax
- Mar 20, 2018
- Lasalle
- 2023 ZR 6000
I had a front air shock that was losing air from the fill valve and when it got low mine would rub big time. As soon as I pumped the shock back up it would quit. I got the fill valve replaced and only had one incident that the rub happened this past winter.
I will put the skid frame to the lower hole just to be safe. Thanks to all for the great info
Phazer2Viper
- Apr 14, 2014
- Slinger, WI/ Three Lakes, WI
- 2015 Viper LTX-DX 15,000 miles and counting!
2008 Phazer GT 128" track 10,444 miles (sold)
2008 Nytro RTX 136" 3800 miles (sold)
2000 Phazer 6500 Miles (Sold)
1990 Phazer II 10,000 miles (sold)
well im havi the exact same problem on my LTX except i dont have the lower holes!! I wonder if it is that front shock in the skid that is the problem??
Sno-Xr
- May 3, 2005
- Clio (Flint), MI
- Nytro
Ok, sorry to have to revisit this with a new question, but is lowering to the lower and middle holes only necessary on the 16' 141"'s? My 15 is in that position, and the track is bango tight with the rear axle allllll the way forward. Seems from what Ive read, there may have been a change to the 16 and newer?? and the 15's didnt have an issue in the upper holes??
InRBigness
- Apr 10, 2014
That is exactly right. 16 and on have different geometry on the rails.
