Stingray I hear you but all posts eventually stray a bit. To keep confusion to a minimum I would always update the first thread. Then people don't have to read 13 pages. Anyone who starts a thread can always edit the first post.
Fendel
- Sep 20, 2013
Installed yesterday AC 160# spring (2704-229). Helped alot. Overall handling is now better. Thanks Stingray for help. How much preload you guys use with 160 spring?
stingray719
Until the collar touches and two full turns is what I run. 65 pounds in front floats and 110 to 120 in rear float
With the cat spring which is dual rate you have 1/4in of adjustment before the first rate is compressed fully and then you are essentially making it a single rate spring. Have it on my 129 now also. Cant wait to try. I believe my stocker was bagged out. Just need snow!
Fendel
- Sep 20, 2013
Okey thanks. Not sure if I understood. Do you have some pics or dimensions? Its now like stingray said, turn until it hits spring and then two full turns. Maybe little too much ski pressurre still, not sure. But, I have blade skis so that will effect too for heavy steering.
stingray719
You can play with rear float shock pressures a bit to take some ski pressure off as long as you don't go too soft
At 2 full turns you are right in the middle of that springs intended adjustment range. Perfect place to start.
Fendel
- Sep 20, 2013
http://3195.shop.textalk.se/snoskoter/boggie/boggie-forstarkning-sr-viper-ny-fastpunkt
Anyone heard about these? E-mailed them and got this reply "Hello, about our boogie kit , stering will be much lighter and nose will not go under snow, we have sold about 300pairs and feedback is only positive". Not much info but still
Looks like they are doing something similar to what the 16's got for a geometry change.http://3195.shop.textalk.se/snoskoter/boggie/boggie-forstarkning-sr-viper-ny-fastpunkt
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
What the heck is it?
I am only literate in english. Lol
Its just a reinforcement/pattern for the rails so you can relocated the holes for the front arm.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
The text on the site says it makes the geometry like the M8000. It should help with lighter ski pressure and reduced steering effort.
Birkebeiner
Birkebeiner
stingray719
Birkebeiner
LOL did that to our red Viper but went to diff spring on the blue Viper. Using a spring allows for many changes without redrilling holes in your skid
birkebeiner
- Jul 27, 2009
- Norway
- Norway
As far as I could see, the site didn't tell what Viper skid these were for.
Birkebeiner
Birkebeiner
stingray719
Birkebeiner
Once again why spend that money when you can buy a spring and do the same thing.
