stingray719
Do the shock need to come off completely to swap out the spring?
Was looking at it and thought it may be possible to just let go the top and swap it right on the sled.
Can it be done?
Yep, spin the adjusting collar all the way down. Then take out top bolt and move top of shock back and slide top collar off....put new spring in and spin collar up so it touches to keep collar from falling off. Put top bolt in, 15 minutes at most to do it.
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Thanks guys
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
got the spring on. Easy peezy japaneezy!!
Never took the spring out.
Got it tightened to about 10 threads showing below the lock nut.
stingray719
Can you lift the skis off the ground by hand now?
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Never checked.
What should I look for.
I guess it should be easier to lift with this spring if looking for a lighter feel on the trail?
stingray719
Never checked.
Yep set right I can lift the skis off the ground, couldn't even budge it stock.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
I assume you still have to use a fair bit of force to lift??
stingray719
I am 160 pounds weight and it takes almost all the lifting power I have but I can lift the skis off the ground. I tried a stock Viper at the snow show last Saturday and I couldn't get close to lifting it
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
Do you lift by the skis or the front bumper?? I'm getting my '15 XTX this week so will try to lift it before I install the Zbroz 160 spring.
Birkebeiner
Birkebeiner
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Sting,
Ok, will try today and post back.
stingray719
Birkebeiner
Front bumper. My favorite in the parking lot is get the guy staring at your Viper to lift it and watch the look on there face as they say "Is that really a 4 stroke???"
You know every snowmobile or Atv I have ridden that had great suspension when you are on it you can easily make it rock back and forth. lean forward front goes down and back comes up. Lean backwards front goes up and rear goes down.
Twisted Pleasure
- Oct 28, 2014
- 2015 Yamaha Viper X-TX
Double checking before I order. 2015 XTX and I weight 200 lbs with gear on. 160 lb zbros spring?
stingray719
Yep, perfect.
Robinmaine
- Apr 26, 2015
- Sabattus
- 18 SR Viper LTX
So here's my thought for me. I weigh around 240. So I was thinking a 180 spring set snug to start (slim Jim Dooley 6" for cornering) and zbroz coupler. I do 95 % trail. I couldn't pass up the price for the xtx.
Sent from my SCH-R970 using Tapatalk
