sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Does anyone know if the wire connection heads on these shocks can be removed and reversed?
Not a big deal but the stickers are on backwards on these shocks and if I swap the shocks to the other side, the connectors are in the wrong configuration to be mounted.
Yes you can with proper sized pin spanner wrench. But depending on model the whole eyelet is offset so shock would then not fit other side properly. At least for the front mounted resevoir like on most now.
I get that the decals bug you as they would bug me too. Could you carefully heat and remove decals and get a replacement decal set?Does anyone know if the wire connection heads on these shocks can be removed and reversed?
RAMSOMAIR
Custom decals for $20
sledheadgeorge
- Apr 28, 2003
Haven't tried that yetI get that the decals bug you as they would bug me too. Could you carefully heat and remove decals and get a replacement decal set?
sledheadgeorge
- Apr 28, 2003
You do these?Custom decals for $20
Ha I have one same thing. If you want these two stickers just pm me your address I will send them in mail.Not IQs but similar.
sledheadgeorge
- Apr 28, 2003
Thanks. Much appreciated.Ha I have one same thing. If you want these two stickers just pm me your address I will send them in mail.Not IQs but similar.View attachment 174983
RAMSOMAIR
No I don’t do stickers but any local vinyl shop should be able to.
