14mtxturboviper
- Sep 1, 2014
- 2014 yamaha viper xtx 153 turbo
Rode for 4 days in Cooke city mt no problems 5th day started blowing 15 amp ignition fuse. I tore it down no obvious chafing or burnt insulation worst possible scenario went thru 8 fuses huge problem. Short of heavy fuse and wait for the smoke any suggestions? Thank you.
kodak
Do you have a rov or tether installed?
14mtxturboviper
- Sep 1, 2014
Tether wouldn't blow the fuse it would just open the circuit and fail to start, I did check the tether though. Thank you I hate electrical gremlins.
kodak
Pro armour tether is hot on the outside on one side and if grounded out it will blow ignition fuse I had mine tight to riser bar took a few minutes to figure it out good luck
- 26K
