IS it possible to ?
rx1forever
utah
:shock: I have a 21 ft enclosed trailer that I have commited to buying already bought! Will the 3 rx1 mtns fit in this trailer? 151s, I previously had an open trailer 3 place that worked, Just hoping that it will work! has anybody done this? or is already doing it ? thanks for your help :-o
Is it 21 feet including the v-nose?
If it's not you have some extra room up front - you can put the front two sleds closer together and nudge the skis up in the V.
I have heard of guys loading 4 151's into a 20' enclosed backwards so the back of the tracks were in the V nose as well.
:Rockon: Thanks for the help the outer length is 21 the inside is 13ft 10 in and then the nose comes in at 4 ft 10 in length. so I have around 18 +- feet to work with, I was going to try loading them all backwards, so that the tracks face the front of the trailer, 1st 2 backwards, then move the ends of them to the outside, then put the 3 rd one up in the middle thanks :-o
