whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Something got caught in rear bogies of my Attack & stripped 130MM wheel. So replaced 130MM wheel no problem & then noticed pinky fingernail size rubber shaved off axle 178MM guide wheel maybe .125" deep. Bad wheel is on BOLT side of axle. Rubber seemed hard but temp was single digits.
A.Is there is an easy way to replace BOLT side 178MM guide wheel without dropping suspension & pulling axle & then rethreading back thru all wheels?
B. Should I just wait for Spring Service when I retire sled for season & replace hyfax. I'll be riding about 1000 addtional UPMI trail miles in remote areas at higher speeds.
Is this high risk?
Is there an easy way to fix wheel that I'm missing?
Is this high risk?
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
whitedust1 said:Something got caught in rear bogies of my Attack & stripped 130MM wheel. So replaced 130MM wheel no problem & then noticed pinky fingernail size rubber shaved off axle 178MM guide wheel maybe .125" deep. Bad wheel is on BOLT side of axle. Rubber seemed hard but temp was single digits.
Is this high risk?
If you are referring to the real axle wheel then just loosen your track pretty much all the way. The very back two nuts (14mm). You will have enough play to easily change out the wheel without removing the suspension..
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
That is what I thought but dealer said no suspension has to come out & 2 man job to thread all the wheels & bushings back thru the axle. So since I have not done this I thought best to ask before I have mess of pieces in the snow.
tender33
- Nov 13, 2007
- Peterborough,On
- 2020 Sidewinder LTX SE, Blue/ Orange
After 1400 mile trip in Quebec I greassed all my wheels today. Just lossen off the track and the back wheels will come out. Less than 1/2 hour to grease and reinstall back wheels by myself.
TurboTime
- Jan 3, 2006
- Cassopolis, MI
- 2009 Yanaha Nytro
whitedust1 said:That is what I thought but dealer said no suspension has to come out & 2 man job to thread all the wheels & bushings back thru the axle. So since I have not done this I thought best to ask before I have mess of pieces in the snow.
You need to find a new dealer because this one is screwing with you and doesn't care much about honesty and trust...
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Just a tip, I get the sled up on the lift and put a two by four on my floor jack about the length of the skid and jack it up under the track to hold the slack in the track up so it is easier to keep the slack in the back around the wheel's otherwise the slack is fighting against you due to sag. kviper
- 9K
