burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I have a JT big wheel kit on my 2018 SW LTX LE. Currently in UP with 2 more days of riding left. Today I lost an outside wheel. Is there a temporary fix I can do to finish this trip? Use a bolt and washer and tighten against the rail?
ksiesel
- Mar 25, 2016
- Indiana
- 2015 Viper RTX-DX
- Indiana
Bolt and washer should work fine assuming you still have both middle wheels left. Many models are / have been delivered right from the factory with only the two inner wheels. You just need to get something in there to tighten the axle against the rail on your right side. I wouldn't be riding it much if at all until this was in place.
Fords4life
- Dec 7, 2021
- South Dakota
With 3 wheels intact, a bolt and large washer will work, as long as hole has threads left in it.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
Thanks. Will try to fix in the am. Local hardware store opens at 9. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
RAMSOMAIR
Hope they have metric hardware.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Where you located?Thanks. Will try to fix in the am. Local hardware store opens at 9.![]()
bleedyamaha
- Sep 28, 2013
- Northern Iowa
This happened to me as well. Lost the wheel and spacer and bolt. Went to the hardware store and bought a bolt and washer. I think I took the wheel off the other side when that happened. I didn’t want to look out of place. If someone knows where I can get another spacer and wheel for my Rtx that would be great This was a Yamaha ad on Kit.
Did the bolt loosen and fall out or snap off?
I can't tell from the picture.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Bolts should have blue locker every time you loosen. Never seen this from that vendors kit.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
Went out this am to assess everything once it thawed overnight. Unfortunately the bolt sheared off. So, didn’t mess with it. Will need to bring a drill and extractor on my next trip.
swrtxlr
- Jun 29, 2016
- grantsburg
- 17 sidewinder rtx le
07 apex gt
00 srx olins
99 mountain max fully modded
gp 292
mod 292
That happened to me last year I rode it two more days and 500 miles back to the truck with no troubles.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
1980 Exciter 300
I really like the design of this kit. I've had it 6 seasons, no issues and the bearings are still good! And I wasn't stranded on the trail when the wheel came off. I talked to the vendor on Tuesday and I have my replacement parts a day later!! Great guy to work with.
- 33K
