putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I love my J&T wheels! Awesome build and great looks!
Ouch you could have mailed it to me in Sprague Canada just north of Warroad MN and I could have mailed it to you USPS from Warroad lol.
Yup!!! and I was under the impression this was a solid axle kit but it is a bolt together 3 pc shaft. It is packaged in a zip lock storage bad and has no instruction. It is 4 wheels and 3 aluminum shafts with 2 bolts seem like very little for $335.00 I could have just run the 4th wheel kit from CAT I have.
christiansenkt
Any Holiday Discounts on the big wheel kit? Id like to order 2.
Give me a call and I can give you a discount on two kits.
Todd
yamaha06
I thought they are all 3 piece shafts though.
- Apr 14, 2003
- Hessel, Michigan
All installed
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Don't forget the rubber caps.
The 137 inch or longer tracks use this 8.5 inch wheels and do not have a way to install a cap. the 7.5's will come with caps.Don't forget the rubber caps.
FYI
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
can you guys make the stealth kit with better looking wheels for the 129 track then the solid ones???
putz21
- Apr 15, 2013
- Tomahawk, WI
Here's my J&T 8" wheels for the LTX with the rubber caps on them. Makes it very clean looking.
Sorry, this is the one and only wheel in this size with a big bearing. There is no other wheel out there. These wheel were make just for this kit only.
- 8K
