the 7.5 129 inch short tracks models do have caps. The larger 8.5 for 137 and longer do not. Just was not made to use a cap. Believe me I tried to get them updated but supplier dose not want to change the mold$$Does the stealth big wheel kit come with plastic end caps? I ordered it but it didn’t come with anything to cover the bolts.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Let me try again. Why do we need this kit?
The tri hub is junk and doesn't hold up to the HP. This gives you a stronger setup and if one wheel fails you have 3 others to pick up the slack. With the tri hub, if anything goes you are stuck where you are and might even destroy the rails. The one on my viper was toast after one season with the MPI kit on it.
