PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
Any thoughts on how to hold the jack shaft to tighten the wobble bearing to 35 foot pounds?? I don't have the spine socket but did make a tool for the bearing nut.
2014 SRviper
2014 SRviper
w8tn4snow
- Mar 28, 2008
- Upstate NY
- 2015 SR Viper LTX DX
How about applying the brake , should stop that from turning eh !
PAvector
- Feb 24, 2007
- Pennsylvania
The top gears and chain need to be removed to tighten the nut, so it's no longer connected to the brake.
I ended up making my own tool to hold each end by going to autozone and tractor supply and welding up some bar stock to some sockets. Trying it tonight.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Can you prevent the secondary from turning by placing a bar through the helix. That would lock the shaft to get your 30 ft lbs.
I do the same thing but in reverse when tightening up the primary clutch bolt. Works fine. Just be gentle.
MS
MS
