K&N Air filter question
I would do the whole package only as everything works together well. Single components are not going to be near as effective IMHO.
canoehead said:
Nikolai Would you consider it worth it all in all?
Considering how bad the lean pop increased, that tells me there was a definite power gain. If I held the throttle down, the sled would continually miss/pop until I let off the throttle. It was doing it before the filter install(from my exhaust), the filters just made it a lot worse. Put a PC5 on and it was night and day.
I'd say it was worth the money once I added the PC5 and got all it's potential. IMO, I think it just depends on the sled. Some seem to pop worse than others, a few people have ran the K&N kits with no programmer and not had any issues.
I have a issue with popping, its at 5-30% throttle. I have a PCV with Ulmers map, I just plugged my laptop in to see if the map was still programed and all seemed ok. I have never had filters on so I dont know if this is common or if its still running lean and needs more fuel. If its not a common noise I may need to just go to a AutoTune and be done with it.
My setup works as designed...Follow the instructions and use the Map from Ulmer and it's perfect...IMO
berge75 mine has never had this issue. I don't run any type of fuel programmer either. I have the stock muffler with the Excell header.
I have always experienced the slight skip upon stabbing the throttle, it has always done this with or without PC3 with an occasional pop sound...
Seems to be present with a aftermarket can. Not so much with other mods. Put stock muffler back on and it wasnt noticable.
