Keeping the nose down
Freak
Spanish Fork, UT
With all this hp and the snow munching 2.5 3.0 pitch I have too much lift. What are some tricks that are working to keep the nose down?
Turn down the boost ............or Install Wheelie Bars ......
............. :Rockon:
.............. :4STroke:
............... :drink:
I guess if I read closer I would have seen that you have a Holz.
Tighten limiter straps and/or increase rear preload.
tightened the rear as mush as possible and loosened the front shock. I thnik my limiter is sucked up to as well as the suspension is moved as far ack as possible. I was told to move the mounting position of the rear pivot back one inch, anyone done this? I was also thinking of moving it up to. Anyone know where I can get those plates they use on the tractor pulls? :drink:
KbxSrx said:
bah, buy an ekholm skid and the troubles all go away.
888-390-5550
Ken or Larry
How do these handle? You cant knock the holz it rides great.
I know about the mtn bike shock. Just wanted to see if there were some free fixes. I will try the moving back 1 inch thing first since its free.
I put a cross-shaft on the rails a good foot ahead of the scissors, then put a limiter strap between the scissor center shaft and the cross shaft.
I used a snowmobile belt cause the cogs keep it from slipping and it is the strongest belt I could find for free. This is a cheap coupling system , couples out so smooth you never know it is there and very effective. I have run this on my 700 nitro burner for 3 seasons without a problem.
pics???
Freak, get the little fox air shock! Just your ticket! and the shock pump that comes with it to easily adjust transfer with it! ;)!
