Boston RX1
Looking for some input on putting a deeper lug track on my Winder. I absolutely love this sled and think it is about perfect. Only thing I have done is change the skis to Pilot 5.7's. I was thinking of going with a longer track model, but do not want to purchase another sled. I do very little off trail, just like to play once in awhile. I had a 1.75" on my Nytro and could go just about anywhere. I was thinking of a 1.6". Anyone with experience with this?
Pstn head
Well...my buddy has a 1.75" on his Cat and it runs hot in fresh groomed hard trail and low snow conditions, it is a 2-stroke which could be the reason but, I bielieve the rad on the Nytros and Vipers played a big role keeping bigger lug tracks sled running cooler on the trails.
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
I don’t have any experience with the 1.6 but I do have a back country x 1.75 on my winder. Absolutely love the track. Wish I would have went to this track a long time ago. 1300 mike this season. Never over heated or ran hot. I also have the stock hyfax on with miles to be had before changing. Many different snow conditions and again no complaints or temp issues. I do run Ice scratchers on my skis and leave them down all the time
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have the Storm 150. It has 1.5 lugs in the middle and1.25 lugs on the outside.
The upside is it works very well in loose trail conditions, moves much more snow than the standard track. The only downside so far is a slight decrease in top speed, which I don't care about, and it seems that after @1300 miles I MAY be starting to bend some lugs over. I will keep an eye on this for sure.
- Nov 29, 2009
- sabattus, maine
I’m looking to do the same thing in the off season. Trying to decide what track to try. Rode up north twice this year and both times hated my sled. The snow up there is usually looser than in my area and the 1.25 RipII is useless. That and I either need a different front skid shock spring or different skis. Just can’t seem to get enough weight off my Curves. Didn’t have that problem with the same skis on my Viper
Pstn head
That's good to know I was thinking of trying the Strom also.I have the Storm 150. It has 1.5 lugs in the middle and1.25 lugs on the outside.
Pstn head
Not sure which carbides your using... but I find the Slim Jims lighten the steering considerably.I’m looking to do the same thing in the off season. Trying to decide what track to try. Rode up north twice this year and both times hated my sled. The snow up there is usually looser than in my area and the 1.25 RipII is useless. That and I either need a different front skid shock spring or different skis. Just can’t seem to get enough weight off my Curves. Didn’t have that problem with the same skis on my Viper
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Had my sled delivered with a 1.6 Ice Cobra. No regrets. I would consider the Storm if there was an Ice version.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Sidewinder carries alot of ice in tunnel. Mine does, at times.
I have an ice cobra on another sled. Good track. But....
1.6 cobra + ice in tunnel = torn lugs. I've seen plenty of pics to question the durability of this combo.
Just FYI......I don't care either way.
actionjack
- Apr 9, 2005
I have not experienced any part of this in 2 seasons.Sidewinder carries alot of ice in tunnel. Mine does, at times.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
I have Sidewinder XTX which comes with 1.6 cobra 141. I went this route mainly to get the deeper track and for the transfer of the uncoupled suspension knowing i was going to give up some ride quality. 1500 miles this year and no problem with heat. i do run scratchers, still have my stock slides in very good condition. my track looks the same as it did on the showroom floor. Between the 137 SE and the 141SE i figured both would need some suspension work for my liking so i went with traction and weight transfer. did the same for the wife also 17 SR Viper XTX. Hygear Pro Linkage and Custom Axis shocks make the XTX rear suspension work excellent.
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I had my LTX LE delivered with a 1.6 Ice Cobra. Love the track. Extra bite on trails and better off trail. I have not had an issue with the ice build up.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'd really like to hear from anyone that is running a studded ripsaw II 1.5. This is what I'm leaning toward after running the ice cobra. It's a good track but I would like more traction. I have the ice build up depending on condition but I take care of it and haven't torn any lugs on my ice cobra, after 3000 miles it is still in great condition.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Ditto, wont own a sled without this track.
