Yes a bolt and spacer would work...never thought of that when I broke my tool...Do you need the tool?
Wouldn't a bolt with spacer work?
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
This is a great mod for these sleds,I've done several. I use the zinc rivnuts with stainless fasteners with no rust problems.
Stainless rivnuts and stainless fasteners together scares me a bit....galling.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
I have the same concern about galling but, I wanted to use the SST riv-nuts as it is easier to replace a rusted fastener that it is a rusted riv-nut. I am going to try the SST fasteners and if I experience galling then I am going to revert to a black oxide coated fastener and replace them as they show rust.This is a great mod for these sleds,I've done several. I use the zinc rivnuts with stainless fasteners with no rust problems.
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
Tom,
I would say this is a great mod for access to everything. There is one step I would suggest we add. I was doing this mod over the weekend. The oil tank side went good. I should have stopped there. Went to do the clutch side. Got the rivets drilled out then went to drill the riv nut size hole for each location. When I was doing the one that is the second one down from the top one to the left of the shock I got into my wire harness right where it plugs into the ECU. It's my mistake for not making sure I wasn't going to hit anything when I made it through the steel. I wonder if anybody else ran into this. I feel sick to my stomach doing this to a new sled. 2022 LTX GT. I am going to try to repair it. A new harness is $500. I guess I'm lucky I didn't get the ECU!
Dude that really sucks. I always watch when I drill thru. Sorry about that as all of mine had nothing really behind that area. I will have to edit the video and add a on screen noteTom,
That's too bad!
Many years ago we were working on a bravo 250 and my employee drilled through the bottom of the belly pan right into the bottom of the fuel tank!!
RobX-1
- Coldwater, OH
When replacing the front heat exchanger, I too was worried about drilling out the rivets so I ended getting/using these drill bit stops.
Farmer 73
- Feb 20, 2015
That's too bad!
Maybe the GT has it relocated there because the power steering.Dude that really sucks. I always watch when I drill thru. Sorry about that as all of mine had nothing really behind that area. I will have to edit the video and add a on screen note
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Also, black tape wrapped around the drill bit works in a pinchWhen replacing the front heat exchanger, I too was worried about drilling out the rivets so I ended getting/using these drill bit stops.
Farmer 73
- Feb 20, 2015
Going to try and repair the harness…,,a new harness is around $500! Sometimes it’s best just to leave things alone! The first new sled I have had since 1994, have always had bought used, couldn’t afford new while raising kids. The first new sled in years and I had to screw it up. Makes me sick! I just didn’t take enough care and look what was behind the panel…. got in a hurry.
VyperNation
- Feb 4, 2018
- MI
- 21 Winder XTX LE 146
18 Winder XTX SE 137
--past sleds--
18 Viper LTX DX
(2) 06 Apex RTXs
99 Vmax 500
I have done this mod to both of my winders, on both sides, and have had zero issues. Its a MUST do honestly imo. I wish they came this way stock. Makes life WAY easier, and a LOT cleaner!
Exactly!! I can’t believe it took me so long to get to it on all my sleds.I have done this mod to both of my winders, on both sides, and have had zero issues. Its a MUST do honestly imo. I wish they came this way stock. Makes life WAY easier, and a LOT cleaner!
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
Barn of parts sells pop pins that I am going to try on my new sidewinder. Ive done the rivnuts on 3 sleds now, they are alright, but I think i might be happier with the pop pins, and they are cheap enough to carry spares.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
these?? maybe......
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I would not use those on the belly pans.these?? maybe......
- 9K
