Leaking turbosmart BOV
Team Yami
Age
27
Upstate New York
2007 Yamaha apex gt
Has any else ever experienced the turbosmart BOV leaking externally around the swivel end? Going to replace but not with another turbosmart if this is a common issue.
Oring on cap must be bad or cap is loose. Never seen this problem with TS BOV.
Did you try to tighten it? All the components on the TS BOV are always loose on all of them I've seen.
I part ways with many on here and say the Turbosmart is a pile of crap. (they do make quality product, but NOT the one everyone is using) Don't buy another. I got one laying around that leaks like a sieve. This was after tightening as mentioned.
This
I have had one of these for 3-4 years now. I did not buy from tomcat. I found it cheaper back then. Not sure about now.
Couple other options for the 998 out there also. You dont have to worry about tightening or anything leaking.
I just went to garage and mine is tight but will still swivel.i assume that's normal.
I have had the Turbo Smart blow off valve since my 2019 SW was new. I disassembled it when new and ensured it was undamaged and assembled properly...the swivel hose fitting has always been able to rotate freely without leaking.
This
Is that a GFB?
Call Turbosmart and speak with a Tech. They may help you out.
