speedjunky
dylanjen9
I think the 2 smaller ones go on the bolts that hold the skid to the tunnel towards the front. The bolt goes through the tunnel then the skid arm then washer then nut.
speedjunky
OOOOOh! you might be right. Thank You!!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
If that is not the case, how about the spacer washer from inside your chain case?
speedjunky
I just looked at the parts break down and no they are not the washers. I usaly assembel any bolts with nuts after I take them out and I see that, that bolt only has one washer and it's bigger and I did put that back on.
speedjunky
I did have the gear box apart also. Could you use the exploded parts view and tell me what number you are talking about? I also changed my exhaust donuts so it could be from that also.
black knight
The big washer looks like the one that goes between the top rear idler wheel and the tube that the big aluminum shaft goes through.(at very top of the rear arm)
Rich Kay
Just a shot in the dark but.... It also could be one of the shims that fit on ethier side of the brake rotor???
sherlock29
2 washers.... front top arms bolts to tunnel.... Big washer... mmmm just put mine baclk together this past week... dont remember that...
121 skid??? 136's dont have idlers on back arm...
speedjunky
The 2 small washers have some corrosion on them so I would have to say they are not from the gear box. I guess they have to be from the Suspension. The big washer has and ID of 30mm, i don't remember anything that big?! The the 2 front arms i did put the 2 fender washers in.
DAGE
the 2 small ones definately look like the washers for the front arm on the skid and the larger one looks like the spacer for the brake disk
Is the big washer from the secondary clutch??
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Did you pull the rear alxe apar, top axle with the to big wheels.
speedjunky
Yes I had the secondery clutch off but I think its to big for that. Yes I did have the rear axle out too but I dont see where that could work.
