What hand guards are you guys running?
I know of the Yamaha ones... they look a little small.
What else is around and has some style to it?
Pictures and links would be appreciated.
Rox flex-tec 2 are nice but a little pricey.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Nytro40th
- Sep 19, 2007
Nytro40th
- Sep 19, 2007
sk-rx1
What guards are those? Like the mirrors also.
wot-75
sk-rx1 said:What guards are those? Like the mirrors also.
Looks like these:
http://www.powermadd.com/products/sno/r ... index.html
and
http://www.powermadd.com/products/starseriesmirror.html
fxnytroxtx
Guest
Rox
Nytro40th
- Sep 19, 2007
powermadd handguards, flares and mirrors. Cat mounting arms.
sk-rx1
Thanks, thought they looked like Powermadd, same as I have. Have a set of extended TriStar mounts on order. Will check out the Cat mounts.
Any clearance issues with the factory windshield?
Nytro40th
- Sep 19, 2007
Others will have to answer that as I have the low windshield.
wot-75
if you have the base model Viper which has a mer height windshield then you cannot use hand guards as there's not enough clearance.STENOD said:Any clearance issues with the factory windshield?
cat ones installed with extensions. main part is hard-ish rubber that will bend. extensions are softer rubber. tight fit to the windscreen
Yamadog
I ordered mine from Skinz.. 2-1/2 weeks ago nothing yet
