seabeeman
- Sep 28, 2018
- Spooner, WI
- 08 Apex LTX GT 40th
I think I've just about exhausted my leads on finding this manual, but I'm hoping somebody can point me in the right direction. I have an 08 Apex GT LTX 40th Anniversary Edition and want to find the service manual, which is listed as LIT-12618-RX-02. This is also the manual for the 08 Apex MTX 40th, LTX GT 40th, LTX, and RTX ER.
The one through the VIP section here is for 03-05 RX1's. I purchased what was being sold as a digital manual for my sled from craigsmanuals on Bonanza, turned out to be the same manual. He said he'd refund but has since stopped responding...not holding my breath. Searching for the part number turns up amazingly few results and I'm started to believe this is a fairly rare item.
Has anybody successfully found this specific manual and, even better, hooking me up/donating it to the site?
On a side note, we a bit of snow about an hour north of me last week...we're getting closer! I ran the Diablo and Apex for a while yesterday just to shake the cobwebs out and breathe some 2-stroke exhaust!
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
From my experience with my previous 07 Apex GT, the manual for the RX-1 and then Apex was a base manual with addendum added on. For example, you will not find a manual for your model specifically. You will find one for the Apex in general, and you will refer to addenda for your model year.
So you can skip over the info for the MTX, even through the only real difference is skid length and A-arm width/skis. You can skip the old Carbed models etc. The manual that would work for any of the Apex GT's will apply to your model just fine.
Now with the 2011 and up, I do believe they released another manual. There again, minor changes to address the EPS and EXUP. The PDF title says 2011-2012 Apex Attak RTX, and inside on the title page says RX-1/Apex. So there is the RX-1/Apex service manual section and a 2011-2012 Apex Supplement in the PDF
if you want a copy, it is 23MB, so I can put in on my NAS to share, or you can download it from the VIP members area here. It will give you the info you need.
RobX-1
- Coldwater, OH
biff is right as I own the same model of Apex as you Seabeeman and the manual I have is broken up into a service manual with 3 different supplementary service manuals where they all share the same LIT number (LIT-12618-02-xx) where xx is the revision of the supplemental manual:
RX10H / RH10SH / RX10MH / RX10MSH / RX10RH / RX10RSH
LIT-12618-02-28
RXW10J / RXW10SJ
LIT-12618-02-33
RX10K/RK/RSK
RXW10K/SK
RX10MK/MSK
LIT-12618-02-39
RX10RTL/RL/RTRL/GTL/ML
RXW10L
LIT-12618-02-44
LIT-12618-02-28
RXW10J / RXW10SJ
LIT-12618-02-33
RX10K/RK/RSK
RXW10K/SK
RX10MK/MSK
LIT-12618-02-39
RXW10L
LIT-12618-02-44
This is same thing that we found.
seabeeman
- Sep 28, 2018
- Spooner, WI
Thank you guys, this makes more sense. I realized part of the reason is I was looking at the PDF in Chrome and not Adobe, so it didn't display that table of contents pane. If I had it in Adobe Reader, I may have discovered that on my own. Thanks for the guidance!
