MrMarc
- Jan 10, 2022
- Northern Ontario
- 2021 Transporter Lite
I went for a ride yesterday , Machine cut out after 1 km of 3/4 throttle , restarted right away , drove around on trail about 1/2 hour , went on lake again about 5 km stopped at ice hut , Machine stalled.
Went in to warm up . 1 hr later go to start up , machine turns over , no sputter , no fire . Anyway to check if Fuel pump is the issue ? No codes being displayed. -10 Celsius outside.
did you hear the fuel pump when you turned the key to the run position?
MrMarc
- Jan 10, 2022
- Northern Ontario
This model no dash or anything until you turn the key to start it up then all I hear is the starter. I got it home , changed the spark plug and doesn’t seem to be firing.I found one wire that looks melted, coming from the cylinder head . See next post .
MrMarc
- Jan 10, 2022
- Northern Ontario
