ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
My sons Nytro is running perfect other than losing power when under strain, up steep hills or in the powder the sled slows rapidly like there's no power getting to the track but the motor runs and sounds fine,doesn't lose rpm's and will rev high to no effect if given any throttle...clutches?
WiscSledder1969
- Oct 15, 2016
- 2011 Yamaha Nytro RTX
How is the belt? Seems like a possible cause.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Its a new belt.Just put on before this happened.20+km on the belt.
WiscSledder1969
- Oct 15, 2016
What kind of track? Possibly just spinning / no traction? May just be giving you the feel of losing power especially on steep hill.
WiscSledder1969
- Oct 15, 2016
How many miles on Nytro?
primary clutch spring would not hurt with a clean and inspect on all parts and bushings.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Is it a Yamaha 8DN belt?Its a new belt.Just put on before this happened.20+km on the belt.
Did you change belts because you blew the last one? Could be some remains stuck in there.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Yeah, it's a new 8dn belt put on because long threads were coming out of the old one.I didn't see anything but I'll check again to make sure there's nothing in there.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Thanks for the replies, I can't see anything wrong.I guess it's got to go to the dealer for repairs.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Sounds like clutch problem for sure. When were they both taken apart and cleaned ( hot soapy water only and some clean dry air to dry them out). Belt dust can make your clutches run like crappie. During the riding season I blow them out once a week and you wouldn't believe the dust cloud.( don't breathe it in)
Pete
Pete
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Missing skid plate under engine maybe?
After the stock plastic skid plate falls off all kinds of snow gets on the belt and slips.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Pete
^^^ truth.
I clean mine @ the end of the season with Simple Green & water but had apparently alot of build up.
Stopped down to Excell's last week having Aaron listing to the clutch rattle, he takes off the panel and I get the "OMG finger rub dirty clutch, shitty belt lecture"
He totally worked his magic + a new belt, man it goes a hell of a lot better now..... The clutch rattle noise turned out to be only 1/4 of the 3 exhaust donuts left on the header and clamps all loose, luckily nothing else had broke yet.
Dr. FeeLGooD
lol Better not let him see mineStopped down to Excell's last week having Aaron listing to the clutch rattle, he takes off the panel and I get the "OMG finger rub dirty clutch, shitty belt lecture"![]()
