YammieMan
Went out riding today, when i came back I noticed my rear outside wheel is missing. How does this happen? Is it easy to replace? Is there any damage that could have happened? I didn't notice anything while riding.. thanks for the help. I will post pics.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
Your picture isn't very clear. Is there a nut or the head of the bolt shaft there ?
Ken.........
Ken.........
YammieMan
Ya, sorry I took the pic right after the ride. I should melt the ice and snow around it and take another pic...
YammieMan
- Jun 28, 2004
- Clinton, Wi.
There is a snap ring that holds the bearing in the wheel. Looks like it failed and what you have left is just the bearing. You'll need a new wheel assembly. Some of the newer wheels have the bearing molded in the wheel.
YammieMan
Ok, appreciate the help. What kind would you reccomend. The other side is a mmp wheel I believe? Looks like a billet wheel. Size is an 8 inch
- Jun 28, 2004
- Clinton, Wi.
Well , in order to tension your track properly, you'll need the same size wheel. I've never used billet on any of my sleds, so I'm not much help there. Check EBay or the classifieds here on TY. Post up a want to buy thread. So one might have some on a shelf they are willing to part with. Good luck!
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You might want to check the other wheels also so you don't have to take it apart again.
Ken...........
Ken...........
YukonMP
- Dec 25, 2014
- Yukon Territory
I'd be looking at changing out both sides rather than keeping/matching the one that hasn't failed YET.
theCATman
Update to the 2010+ spoked black wheels with replaceable bearings.
YammieMan
You guys are all awesome! Thanks for the help.. is this something a guy could do in his own garage, or better to bring it to a shop as in sure they have to loosen the track and adjust the alignment etc.
YammieMan
I have an RX1, they didn't make the RX1 in 2010, so which one should I go to? Nytro?Update to the 2010+ spoked black wheels with replaceable bearings.
theCATman
Apex or Vector wheels.
theCATman
And yes you should be able to handle it yourself, as long as you have decent mechanical equipment and skills.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
You mean some of the older wheels since Yamaha went with wheels with replaceable bearings later on. Looking at the pic, the bearing itself has failed, leaving you with just the inner race. I can tell because the washer only covers the inner race. This could happen on wheels with or without replaceable bearings. Since yours is an '03, if it was an original wheel, it was likely the non-replaceable type. I'd recommend the replaceable bearing type since they are serviceable and are actually cheaper.
