hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I've been thinking about the bad dead spot from low beam to hi bean and started probing the plugs on the harness and relay to find a simple way to keep the low beam on with the hi beam as it is in a lot of street bikes, my buddys V-star being one of them. Turns out you can just bridge the red and white wire in the headlight switch housing and low beam stays on constantly and only hi-res gets switched. Tried it behind my shop tonight and it's awesome!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
great Idea buddy I'm doing it!!!!
Dinner
Just be curious how long the bulbs last and the bulb housing. Not knocking you one bit for trying! Wondering if our headlamp housings can handle the extra heat? Or am I just over thinking....
hellflyer
- Dec 2, 2008
I'll find out! Apparently some models of skidoo run this way. Got to be cooler than a street bike in the summer. Usually switch to low beam near roads or when oncoming traffic anyway
Dinner
Yeah that's true! Maybe I'll do this as well and give it a go. Would be a lot better in the forests at night!
hellflyer
- Dec 2, 2008
That's why I did it hi beam does let you see in front of you and low beam is useless over 100ft
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Would this work with HIDs as well?
hellflyer
- Dec 2, 2008
I don't think so! From what I understand hid have only one bulb that changes position for hi /lo
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I'm definitely going to try my this I have led bulbs on the way so the extra heat or power will not be an issue.
That would be a awesome Combo!I'm definitely going to try my this I have led bulbs on the way so the extra heat or power will not be an issue.
trevorl1
- Mar 14, 2015
- Nova Scotia
I'll post once they come in and test them, I have two vipers so it'll be easy to compare before and after.That would be a awesome Combo!
hellflyer
- Dec 2, 2008
I'm going to do led bulb also that's what's In my buddy's V-star 1300 that gave me the idea of keeping the low beam on full time.
hellflyer
- Dec 2, 2008
Yesterday we did the low beam mod on my buddy's nytro xtx. Works good just a little harder to do ! Had to jump it at the relay between blue and green. Green being low beam.
Skytt
Got any better picture on which harness it is? Just ordered LED bulbs from China so cant wait to try this
hellflyer
- Dec 2, 2008
In the viper it's right behind the hi beam switch in the housing on the bars! In the nytro it's the third relay from the front
