hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I wonder if they headlight will build ice with no heat! Had a friend that drives truck and said that was a downfall of LEDs, taillights always snow covered.I had hid in my truck and switched with these new leds. It seems to work the same as the hid i had in the truck. The new leds are getting better, I'm trying them in my sled seems better than stock that's for sure and no heat.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I figured I would roll the dice and try them out for $54I wonder if they headlight will build ice with no heat! Had a friend that drives truck and said that was a downfall of LEDs, taillights always snow covered.
hellflyer
- Dec 2, 2008
I did get some also! But I'm getting them for Christmas from my kids! Wife and I figured we may as well get what we need and let them give it to us! LOL I got these
https://www.amazon.ca/dp/B01GRDJI1U/ref=pe_386430_121528420_TE_dp_i2
saskieXTX
- Nov 24, 2015
- Saskatoon
- 2015 Yamaha SR-Viper XTX
1997 Yamaha Vmax XTC 600
What bulb did you get... I wanna order the same thing.View attachment 123755
This is what I used purchased off amazon 53.99 Canadian they looked good and got them for my truck as well cannondale27
Sent from my SM-G935W8 using Tapatalk
- Nov 29, 2009
- sabattus, maine
Yes, I understand the LEDs will draw less. I'm wondering about jumping the wires with the stock lights so both low and high beam are on when switched to high beamI'm a tech by trade and as far as I can see that it draws less because they are led if using hid it would draw more
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
With the stock lights I can't see it being a problem with both not a lot of drawYes, I understand the LEDs will draw less. I'm wondering about jumping the wires with the stock lights so both low and high beam are on when switched to high beam
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
H-4 from green lWhat bulb did you get... I wanna order the same thing.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I broke the connector on the white wire, anyone have an idea where to get one or what they're even called?
musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
I would watch running both filaments at once, those bulbs are not made to handle that extra heat! I have seen bulbs melt the glass and torch the reflector on atvs due to the high beam switch sticking on.
saskieXTX
- Nov 24, 2015
- Saskatoon
New LEDs looking good...
trevorl1
- Mar 14, 2015
- Nova Scotia
I ended up just ordering a hid kit. I wanted to change my bulbs to get the most light output and that will be the way. And they use about the same power as led once they are warmed up.
hellflyer
- Dec 2, 2008
I ran my the other day for 2 hrs on hi and no issues, -2c and low speed drifting. Should be less heat when it's colder running at speed. I have the hi output silverstars I through in last year.
Skytt
- Mar 8, 2016
- North
- Sweden
- Phazer MTX -08
Put in my new LED lights from china (http://www.ebay.com/itm/282259992630) Ill put the link here so you can see what im talking about. Was just about to bridge the White and red Cable but decided to test the lights first.
To my surprise both LEDs fired up right away, both lights staying on. At half light only 1 diod on each side burned but at full light both diods fired up.
So my question is, do i need to bridge it anyway? Cant see any reason right now but im curious why both lights fire up right away.
I hope you guys understand what im trying to explain
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
From what I understand is on low beam one led lights up and on high beam two leds light up this is correct no need to bridge this is exactly what mine are doing
nytrorider28
- Nov 14, 2010
- Marion, IA
- 2014 Yamaha SR Viper LTX
2007 Skidoo MXZ 600 SDI
Past:2009 Yamaha Nytro
I can confirm on the LED kit. I put is xkglow kit. They are two sided. Low beam on one side high beam the other. When high beam is on both high and low beam are on. Rode this past weekend with no iceing issues.
- 29K
