Dinner
Did this last night while tinkering out in the garage. See how it does once winter actually gets here.....
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
Ok I tried bridging the wires, but when I hit the high beam switch it would just change over to high beam only. I don't get it really.
They are led bulbs but I can't see that makes a difference.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Hmm! The red is constant power and the white goes directly to the bulb so it's got to stay on!
trevorl1
- Mar 14, 2015
- Nova Scotia
So white is low beam?
hellflyer
- Dec 2, 2008
White is low! If you connect it to red ,low will all ways be on. But you have to leave the red connected to where it is to power the hi beam when you hit the switch! Hope that is clear
- Nov 29, 2009
- sabattus, maine
Sure would, good idea hellflyerThat would be a awesome Combo!
trevorl1
- Mar 14, 2015
- Nova Scotia
We'll I've been scratching my head for the last hour, no way would both high and low stay on at the same time, checked the wiring everything was right.
After a while I thought let's hook up the bulb direct to the battery and well I guess these led bulbs won't turn both high and low on at the same time.
I can't believe it.
I can't believe it.
Still better than stock right?
hellflyer
- Dec 2, 2008
That sucks! I know my buddy ordered some for his bike and they are both on in hi beam mode! I just ordered some to and hope they work.
Has to be a way.
hellflyer
- Dec 2, 2008
You would not believe the light pattern with low and hi on ! I'll keep my standard bulb if I have to.Still better than stock right?
trevorl1
- Mar 14, 2015
- Nova Scotia
A little better then stock, I left one viper with the stock and the other with the led.
Not much better but a little. They look way better though and if I could get both high and low on at the same time it would be awesome. The bulbs I have project exactly like the halogen not concentrated like some people say.
Just stupid they don't stay on together must be something in the ballast.
Must be. Well worth trying. What about one on high and one on low. Would think that could be done?A little better then stock, I left one viper with the stock and the other with the led.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I put led in my viper and nytro and wanted to do this bypass for low and high beam at same time but for some reason on high beam they are both on guess I don't need to do this
So which LED's did you get?I put led in my viper and nytro and wanted to do this bypass for low and high beam at same time but for some reason on high beam they are both on guess I don't need to do this
- 27K
