200smk
Fix Powersports also has a wheel setup to go in front of the idlers (drill hole). I have emailed them (wed) for info but have not had a reply yet......
Isthatahemi
200smk said:Hmmm......Is anybody with Phazers getting 1000 or more miles on their Hyfax???
2500 miles with limiter strap tight. Lots of groomed trail.
200smk
How tight do you have your strap?? I moved one tighter from stock so far. How is the rest of the handling with the strap being that tight?
Thanks!
Thanks!
GypsyRoots
- Oct 29, 2006
I put the low snow wheels on my Venture Lite from the get go and I got 3500 miles out of the first set.
Still working on the second ...
I see even the Yamaha wheels can be mounted in front where my wear was.They use some real small wheels but should do the trick.I am taking the SkiDoo wheels back and getting the low snow wheels.Thanks guys.Saved alot of work.
