brmurph
- Apr 28, 2013
- Austin, TX .
- 2012 APEX XTX
- Lake Vermilion MN
What are you guys doing to lube the steering on the APEX (or any sled actually)? I am specifically talking about the ball socket joints. Should this be lubed and if so with what?
Thanks.
Thanks.
WD-40 or Silicone Spray.
Winderallday!
RAMSOMAIR
Fluid Film is thick and sticks well. Also used chain and cable lube but can be a bit messy.
brmurph
- Apr 28, 2013
- Austin, TX .
- 2012 APEX XTX
- Lake Vermilion MN
Thanks.. Is there anything specific to grease for hard steering? I have 2012 APEX XTX and it seems like it steers a little tough for a machine with power steering. To be fair I don't have a lot to compare against.
Winderallday!
There are some nylon or HDPE half bushings on the steering post below the riser, and also where the steering tubes/linkage transition toward the front of sled, one above the reverse mechanism and one at the front by the airbox, I always sprayed fluid film in those locations too. Parts 15 and 22 in the pic.
brmurph
- Apr 28, 2013
- Austin, TX .
- 2012 APEX XTX
- Lake Vermilion MN
Thanks! Can you get to these without removing the gas tank?
