M-10 121" or M-10 136"?
BlueBlood
Northport, Michigan
Probably going to replace the stock rear with something that actually works. Definitely M-10, but I'm not sure about which length. I had a 121" on my Blade (until it burned to the ground on Sunday), and loved it. I know the 136" would ride better but not sure about push in corners. I'm going to update the front suspension and also put on FLOAT shocks or Ohlins, and C&A skis. I do like to go off trail when I can, either way it's getting a Ripsaw. What do you think?
OK, I stretched mine to a 136 this year. Ripsaw w/162 up the middle. Ohlins all the way around. Heavy spring. A little push w/Simmons, I am installing the C & A on Thursday. I like it better than the 121. But if you do the 136, you HAVE to install a rear exchanger. YOU HAVE TOO!
greenmachine said:
I don't have the rear exchanger and the light has never come on.
Jim
Have you checked your light to see if it is working? LOL
