ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
Did it increase your vipers top speed? How much did it cost you for the M20? Do they make Dupont slides for you M20?
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Yes sir!Do they make Dupont slides for y
This is a Yamaha part # for Dupont slides with a Polaris rail profile, which is what the M20 has.
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
that seems like a better solution than fully clipping the track. Thats a pain in the ars!
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Top speed didn’t change much cost was around 2k which is no more than a pair of good shocks and a 4 wheel kit it uses Polaris edge slides I haven’t found DuPonts for it yet but after fully clipping the track I have 2k miles on a set and they look new yet.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Yes they were. Sure was nice never having fear of the rear kicking. I smoked a lot of 5 year newer sleds in the bumps with that setup but hated having to adjust it for conditions all the time. Eventually broke front arm right off when I hit a few big ones on a uphill that I didn't expect and had suspension set real soft. Compromise was setting it stiff and leaving it. Was way to small a sweet spot in that skid without adjusting. Air system and adjusting it I am sure helped broaden the range a lot.
I had a M10 on my 1998 SRX 700s so when I bought the M10 I purchased the skid with the Ohlin shock option. They fixed the narrow performance sweet spot on the M10. What a difference, with the M10 the SRX just swallowed bumps! Perhaps better than my 137” viper with Hygear Axis Pro shocks.
