Custom Rx1
- Jan 16, 2007
Just woundering what it is like? What kind of speed do you lose? Is it worth the money? I have an o3 RX1
BlueBlood
If you have an '03, then anything is better than what you have. I've been very pleased with the M-10's I've had, never ridden an AD Boivin however, so I can't compare. Any top end speed you might lose is minimal in my opinion, and how often are you going to be there anyway? If you care about every mile per hour, then don't get one. But it does a great job in the bumps if you set it up properly. JMHO
LazyBastard
Stock 03 skid is JUST FINE if you set it up right. Set the FRA high and the preload low.
If you want to modify the sled's length though, don't mess with extensions - get a skid that is the length you want, like I did.
Groomerdriver
blue rocket said:Just woundering what it is like? What kind of speed do you lose? Is it worth the money? I have an o3 RX1
I put one on my 05 Vector and just love it! M10 with dual Ohlins clickers. Easy to install and dial in. Have heard that if you're more of a ditchbanger the ExpertX might be better for you.
You can find used M10's on the net...just make sure you buy a genuine M10 from FAST, and not a M10 from a Polaris....they are different...and NOT different better!
You might want to call FAST (www.teamfast.com) as I think they have used,reconditioned M10's from time to time.
PM me if you want any other info.
